mechanical 2010 opens me only one file at a time
  • Thread starter Thread starter Attila29041981
Attila29041981
Good morning to all,
I press that my operating system is seen 64 bit, mech sp2.
It happens to me that mechanical 2010 opens only one file x time, or better if I have already opened mechanical, and I double clik on another file dwg, opens me another mechanical and so infinitely.
is not the command "sdi", opening only one forced file.
I installed the 2 hotfixes on the autodesk site:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=13484660&linkid=9242019
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=13484815&linkid=9242019I don't know what to do anymore. .
is that it is quite annoying.
thank you so much to all and good work
I would have replied to install the hotfix... But you did, so...
Do you have active uac?
If yes, try to turn it off and check if so mechanical works.. .
I have the same configuration, and after the hotfix I noticed an improvement, even though sometimes the problem resumes.
Now I am automatically dragging the file to explore resources directly into the autocad window (obviously not in the drawing area, but in the " menu area").
There is a variable set on "zero" that should be put on "one" to open file in multitasking, if I remembered what it is....just I write it.
same problem on a station of my client and using little the program I don't know how to solve it I remember that it is a settling but also trying to pass I didn't find it... but here comes the fantastic assistance... it is here to explain the inventor vault but maybe a small question I can ask you... I let you know.
... he solved it by typing "sdi and setting it on 1". .
but I think I understand that in the case of appropriation this solution has already been excluded...
to me it works if imposed sdi to value 0
if it is at value 1 inhibits multiple opening
has right plannerroad, to view multiple open dwg files at the same time in the Windows application bar the variable to type in the command area is "taskbar" and the value is 1, happened also to me on the first day of internship with mechanical 2010, I had to repay absurd variables
Good morning, I just signed up to give my testimony about this problem, solved in this way: first I installed the autodesk registry key that is here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=13484815&linkid=9240898then from explore resources I opened a random dwg with the function "open with" --> autocad dwg launcher (thanks to a report on this forum)
now every double click opens the files in the same session. Sometimes it may be necessary to apply more than one solution. . .
Good day
