[mechanical 2014] problem board cartiglio a1
  • Thread starter Thread starter Vit1
Vit1
Good evening, everyone.
I realized that the 2014 version of autocad mechanical (proven on 3 computers, on all 3 is installed the software with regular student license, 2 with window 8 and 1 with windows 7) is missing the edge for sheet a1. I do not think it is a problem of my installation file, I checked and looks like the one currently present on the autodesk site.
the problem is that there does not seem to be a board for the format a1, while there are those for all other formats I checked (a2, a4, a0, and several multiples).
I then tried to create a .tit file following the procedure described in the software guide but I can't find the .dwg file containing the board but can't make the dwg recognize.
Can you please indicate how to create a new board and insert it into the program as a board with a cartella?
Thank you!
Check under this address of your computer
c:\users\public\documents\autodesk\autocad mechanical 2013\acadm\gen\dwg\format
for destination folder settings see pdf
