mechanical ansys pressure tank simulation
  • Thread starter Thread starter olympio
olympio
First of all I apologize if I didn't introduce myself in the appropriate section, my muscatiello olympic and I am a graduate in mechanical engineering to the polytechnic of torino, doing a static analysis of a pressure tank with ansys mechanical, someone would know how I can select all the knots that have a certain coordinate in terms of roof?
In the Cartesian plan I would have used "nsel", but here I don't know exactly how to move.
thanks to everyone in advance.
change coordinate system. if your tank has as a z axis you can use the command "csys,1" and then use "nsel"
Thank you very much I will try! !
In fact I did so: I selected the line and selected all the knots along that line with nsll, but I will also try your solution :finger:
