mechanical autocade 2024 per student
Claudio 10
Good morning.
I wanted to know if you can get the 2024 autocad mechanical tool set with a student license.
I have just installed autocad to version 2024 and I would like to implement that tool set to export the design from inventor and open it in autocad mechanical having a layer for each component so as to simplify some phases after the table.
going to the autodesk site and accessing with my student account I don't display the mechanical package as ever? However, if I go to the products section for students without accessing the account I view the tool set in the class/laboratory section.
Thank you very much
no in fact for this and I wanted to know if you can get with the student account or if it is already installed in standard autocad and how you access it.
What a shame!
because it would have made me comfortable exporting the mechanical design and opening it with autocad mechanical I would have had a layer for each component.
we hope that in the future they will arrange this particular
thanks the same
What a shame!
thanks the same
I'm sorry, but why would they do that? mechanical is an evolved version of autocad that contemplates several automatisms that are useful only in the working field.
does not seem to me from the profile that you are a student so why should you use a program that in this version is exclusively for teaching and not for profit?
I just need to be able to process autocad designs better by inventor.
regarding the use of this type of license I am authorized by attending the university.
anyway thanks for the support!
it is not that because you are enrolled at university you can use educational software regardless. If you are using it for work, for profit (I don't know if you fall into this case), you're not authorized at all! Sallo.. .
I know I'm aware of this, the license should only be used for educational and non-profit purposes, as I'm doing, all the projects I've done and I'm doing are only for educational purposes.
