mechanical extrusion
jim78b
I was doubtful, in the mechanical you can draw in 3d? I tried to make a polyline of a sheet then extrude but tells me that it does not find the solid!
Mechanical is nothing but autocad with "some" (tante) extra thing... so what you do in autocad you do in mechanical.. .
said this, for the very little that I used the 3d of autocad, to make a bevel to a solid is the same valid command for the 2d (that of autocad, not that of mechanical). .
hi!si look I folded the sheet, you say to use the bevel command and select the faces?but it seems to me that it does not...
