trebbia
Hello everyone,
I am about to venture into the mechanism function of proe wildfire 5 and I kindly ask if there is anyone available to introduce me some basic notion especially in the use of cinematic constraints. I have already managed to do something but I do not know if it is the most optimal road...cmq I list some concepts that I would like to clarify and know how to build in a simple way:
1) coupling dentate wheels, whose driving force transmitted by a tree.
2)two serrated wheels on the same tree (motor the tree)
in particular what bond should I use between tree and toothed wheel? and how to set it up?
Is there a particular order to perform in the assembly or is it indifferent? (e.g., the shaft first or the gears first)
how constraints work: pin - tree - planar - rigid?
I realize that perhaps there are too many questions but I thank you in advance for your cooperation.
