mechanisms with under assemblies - inventor 2020
  • Thread starter Thread starter teddy
teddy
Hi, everyone, I'm having trouble moving the sub-assistances into a father together.
When I try to drag a single part, select the inside subaxieme, making the movement impossible.
use inventor 2020, do you know how to tell me any method?
It seems to me that even with inventor there is the flexible mode that allows the subaxis to move interacting with the upper axieme for the degrees of freedom it possesses. search the web you will surely find.
Thank you, I try and tell you.
hello to do this in a practical way, you can open the subaxis, create a position with the constraints that you do not care about suppressed and by a name.
then in the general assembly select the subaxis and button dx "flexible" and then choose the unrivalled position and move it. So you can move it, and if you don't need to change your position and come back as before.
I'll consider it, thank you very much!
