Mematic 2 touch
  • Thread starter Thread starter vampire
vampire
Hello everyone
how do I simulate the rotation of two contact gears? :cool:
what constraint and joints should I set up in the cinema module?
Thanks :finger:
And you're the moderator? ?
When I'm awake, I try... but not always
you just need to define rotation couplings for the wheels (plan and line), and then define the pair through the function that I indicated you.
joints can be created manually or automatically recognised through joint constraints.
However, in the online guide you will find two quite explicit examples.
you could be a little + design.
I don't know how to do this.
with ke kosa I realize the contact between the teeth: with what command
but do you have to simulate the relative movement of teeth or do you have to simulate a cinematism of dense wheels?
Okay, I got it. I used the command you told me at the beginning:biggrin: and I visualized on ytube how to apply it. Now I find myself with the geneva mechanism and there will be some good ones. :tongue:
I have difficulty with contact pivot wheel/adduced wheel pocket
nn and joint prismatco in gearing
see if you are sufficent this model
