merge two inventor axis into a single set
  • Thread starter Thread starter Henry84
Henry84
Good morning to all,
I would like to ask you a question: How can I combine two inventor axioms into one set, without losing the constraints in each set??
insert the 2 assemblies into a single parent, then raise all parts at the same time, empty the 2 assemblies
original , if you want to delete them and so name the new remaining together as you wish ..
if I don't remember badly, using an older version of 2014 the constraints jump when moving components from one together to the other (or copying glued parts between them)
it seems to me that the move did not have problems, while the copy/paste that holds the constraints is actually one (for me wonderful) novelty of 2014...
the system proposed by eugenesis is both practical and the only one I know, done the same thing just yesterday...
-- edited
to tell the truth if the union of the assemblies serves only for the distinct table you can join the assemblies in a parent set (or even insert one inside the other) and, without moving the components, set the assemblies as "invisible": in this way only the components appear in the separate ones.
then maybe it was from 2010 onwards, boh.... I don't remember.... on 2009 I'm sure the bonds disappeared and all had to be remitted.
