crimas
hi, it is from a lot that I do not write, today I have faced a problem that goes beyond my abilities, in practice I have a 3d model made of low poles (those big triangles that form a three-dimensional model), from this model I have to succeed in selecting certain faces and create a mesh/surface apart for each triruption so that I have the entire model constituted by many sub mesh/superfici ones that compose it
the work is similar to the construction of a football in the form of icosahedra, starting from the model 3d, you decide which faces can remain united on one side and which will need a joint, develop on the plane these surfaces and eventually assemble the ball.
for greater clarity I leave you a photo in which there is a model 3d low poly in which each color represents a ragrupption of faces that will constitute a single piece of sheet that will have to be cut and folded.
the most immediate solution that came to mind was to go to redesign every face and then to force to export to dxf and to join the various triangles I was going out the single piece of sheet to cut, but this operation seems to me to the as laborious and little intelligent, as well as losing all the information on the fold of the sheet because in fact they join triangoli with a thickness null in a 2d design. I hope someone can suggest a smarter operation to do this job
Thank you in advance.
