mesh
  • Thread starter Thread starter Dani84
Dani84
I'm experiencing problems with the mesh of an object.
I am using the bottom-up control, especially the swept command for meshare half object and the other half for extrusion.
the resulting mesh does not coincide with geometry: I then used the "edit mesh" option, but it does not allow me to carry the knots on the surface, as the surface is internal and does not make me select (the surface in question is the one in common between the two meshate half).
Any suggestions?
I solved the problem.
I knew that it was possible to partition the object into 2 cells, only that I could not join them with the "tie" command (as I could not select the internal surfaces to join). solved this I divided the object into 2 cells, I meshate them separately and then joined them with the command "tie".
thanks the same for the attention. greetings
Can someone tell me how to hide the mesh when I go to visualize the results, so that I see my structure exclusively colored by the level curves? ?
