messa and tavola problems
  • Thread starter Thread starter Naeto
Naeto
Hi....I have the need to put together on the table....I would like to know if it is possible to represent in a window a part as reference (with the result of seeing it drawn) and in another to see the same object in a normal way....
when you create the view of the design you have the possibility to put the hidden lines the normal view or the shaded one that selects when you make view of the design you find "style" at the bottom right
I have explained badly....I need a window where I see a set of parts to represent only one part as a reference part. . ..this is that you can do by right-clicking on separate components and then selecting in the component structure column the affected part as reference object....my problem is that in all the windows of my table the part is updated and it becomes detained and transparent
Maybe and I say maybe I understand what you mean.
Let us start by saying that the various representations on the table are called views and not "windows".
you create the first view as you described me, to make sure that the others are not like that, on the double click view, you appear the window "drawing view", go on "model status" and where there is the line styles voice go to tick "as parts" and right into "hidden line" snacks on all bodies, from ok and should do what interests you!
