mirror function and constraints
gymbg
Hi. .
I have to do a set using the mirror function to repeat the same pieces (I can't use the series)
using the mirror function the mirrored pieces do not "bear" the constraints placed on the original? otherwise I spend more time putting all the constraints I need....
alternative solutions? ? ?
I had the same problem, but I didn't fix it.
But I have noticed that if the part is fixed the elements of the series will be fixed, it is not much but it is already something
