daveriva79
good morning, is it possible once the table of a piece, whether it is ipt or iam, to obtain directly the table of the same mirrored piece?
True. the problem of writing a dx piece and a sx from encoding problem to whom, as in my company, must supply the spare parts with spcifiche.the day you can easily do, all those using solidworks will pass to inventor.
the fast solution must be found with careful management of the assemblies and details.
I prefer to move the processes that make the piece symmetrical rather than use the function of derivation of the details (or worse of the overalls ), at the cost of working the double in case of changes.
the table always has a considerable cost compared to the modeling.
there is also who puts the label [ 1 pezzo dx + 1 pezzo sx ]Sometimes that's enough, and if that's enough, I will.
No!in solidworks you can already do... pass to the dark side: eek:
I agree, neither did I appreciate this system but ...comau, in the past years (now I no longer work for them ), had also codified this system : draw the right and give it a number, then take an empty format, give it another number and, in the format put a label saying : " symmetric piece to ...... "Putting the word a dx piece and a sx is a shortcut but it's a cabbage in my opinion!
the design must be read by everyone not interpreted!
I'm sorry, is it just for the table?in solidworks you can already do... pass to the dark side: eek:
In that case it is no longer a specular piece. and you wouldn't put the label [ 1 pezzo dx + 1 pezzo sx ]If I make a symmetrical piece where I add or remove work, like the holes for a flanged motor?
same objection made above; if a piece is speculating and I change the right version, I also change the other. if I do not want to make this mold in pdf and with acrobat mirror the portions of image that I need without needing autocad.so much it is worth mirroring a table of autocad, at least do not enlighten you that it is associated with the model.
