mirrored text in blocks
  • Thread starter Thread starter France78
France78
Hello everyone.
I have the following problem: I have blocks with inside a text that covers and mirrors inside the drawing. but also the text.
How can I do to avoid the text mirror included in the block?
I tried with the command "mirrtext" but it doesn't affect the internal texts to a block.
thanks in advance for every suggestion. :finger:
I think it is impossible, as mirrtext works on attributes, and not on simple texts belonging to the block.
The only loophole is to create another mirrored pluto block compared to the first pipe, but with the text already correctly oriented.
other ideas..?
I've been thinking about another loophole, the parametric block.
creating a mirror parameter within the block, I can copy (not mirror) the block in the destination location, then activate the parameter and mirror the block.
personal note: I don't know whether this solution is better or that of creating two different blocks because the parametric blocks are not so simple to create.
