missing commands
  • Thread starter Thread starter arts1983
arts1983
Hello everyone, I'm desperate!
I don't know for what reason, but I have disappeared the commands that allow to draw (line, curve, etc.), the checkout of the command and x that allows to conclude a command without saving the changes, which appear every time you create a new complex element (tect, floor, staircase, etc.).
it happened to me once and I fixed repairing the installation. I work with revit 2012 on win7, but it also happened to my colleague who works with revit 2013 on win8.
revit 2013 is not compatible with win8 but most likely it is a problem of .net framework
I apologize for not responding immediately and thank you.
but if it is not compatible that I have to do? Uninstall it (.net framework)? I have the latest version, I don't want the problem to be due to the recent update of windows... Damn it!
you have to continually click on the command bar above until the right command series comes out. I had the same problem, circumvented in this way, and then solved with revit 2014
I had the same problem, caused by the upgrade net.framework 4.5.something.... I had to uninstall the updates of this. ..disinstall the autocad-revit&co package and reinstall everything!
I don't tell you the fun!
I apologize again, I usually follow the discussions that I begin or which I participate. I solved with an update downloaded on revitclinic.
ah, before opening the discussion I also tried to uninstall/install the program because initially I had solved "repairing the installation".
Sometimes it happens to me with rvt 2014, I have windows 7, sometimes disappear the lower part of the command bar except the titles at the top , and just click on the button at the top to dx to shuffle the screen and then recycle it to re-enlarge it and the problem disappears, sometimes instead disappears just the whole bar and then I have to close and raise the program and the problem disappears
Hello, everyone. I have the same problem and I realized that, having installed autocad 2015, the .net framework has passed to version 4.5. to be able to work revit 2013 with this version, do you have any suggestions? or on the contrary, if I issue version 4.0 of the framework, autocad 2015 will have problems?
thanks in advance for any help.
hi umberto87 I know that mom autodesk tried to solve with hotfixes for the different versions of revit.. Try to check.
... I tried to open the rv2013....and it doesn't bother me. .
confide in good luck!
