stefanobruno
after connecting the laptop to an external monitor, it happens that the second dialog that follows the block insert command, the one that allows the choice of the file to be inserted, is no longer visible.
this is also repeated on a single monitor.
the window is definitely there, this leads to the fact that the program expects an input and does not proceed if not pressing esc.
As mentioned, the window is there but it ended out of the monitor.
Is there a way to bring back the windows to the center of the screen?
This is happening with rel. 2004 (I know it is old but it is the release, the only really working and superpersonalized and we have no courage to abandon it )
opening files with other rel. That doesn't happen.
the operating system is xppro and the laptop is an acer with ati.
I also tried with "moveme", a prog. that promises to do what I need but I did not get results.
on other occasions and with other prog. I solved by modifying the coordinates in the log file, but I just can't fix it.
bon, now I cry there and greet you.
