missing replacement files in the list
  • Thread starter Thread starter genesis1975
genesis1975
Good evening to all,
I have a pack and go of a set in which I have replaced many components to give back references to a shared folder, which had been interrupted...now from the list of the axieme I am renamed all the parts and sub-assiems with its codes, but there is a surprise...the old files I have replaced there are still in the list and there are no new files with which I replaced... How can I continue?
Sorry my question is partly stupid because it's obvious that the files I replaced will be where I fished them, but as far as the old ones are still in the list they were also replaced. Why?
Can I cancel them?
when you pack and go there's the main axieme, subassiemi, all parts, and drawings if you include them, all in the same folder...in this list are still present certain files even if I have replaced them with others.... can I delete them?
if they are present means you have not replaced them.
I can cancel
if solidworks inserts them into the pack&go means that somewhere they are used. if you can delete them you can only know that you managed the project
It's an old pack&go, I later replaced components, but these continue to appear in the list when you double-click the folder.
For example, I deleted subaxis, created new ones, replaced many files, but the old ones still have
