missing toolbars in autocad 2009
  • Thread starter Thread starter francesca aiuto
francesca aiuto
Sorry, but I've never been through this.
this afternoon opening autocad 2009 I disappeared everything or from the command of the line to the layers to finish at all oppositions. to work I have only remained the keyboard command. I practically no longer have any dialog. there only the top left with file and window and just don't know how to do it!! help! !how to restore everything as you can do? Just to say I don't even have the right button if you want to give commands from them.
Thank you very much
I reappeared all by putting acadsampleworkspaces menu but the same does not work the right mouse button. How do I do that?
If I put acad .chei away everything!
You practically changed your work area and now everything works?
and the right mouse button what does not work?
Don't you see the menus? in this case go under options -> user preferences -> quick choice menu in the design area.
Meanwhile thank you so much for your valuable help ... I had never been enrolled in a forum and this besides being beautiful there are many people available. then the problem that I work through keyboard and some commands from the right mouse button. Now I don't see the dx key menu and I couldn't find something to make it work. But there's some keyboard command that needs to be inserted? that is disabled? I know it is not possible that from the point in white everything disappears!.
then I changed work area not and acad.cui because if I write menu and activate it all the commands from the first to the last disappear all . why? how can I do? Also because as I have to do university deliveries if I don't hurry I'm done. What if I don't uninstall it? And I'll take it back, but then a slaughter I already know! Thank you very much
....then the problem that I work through keyboard and some commands from the right mouse button. Now I don't see the dx key menu and I couldn't find something to make it work. But there is some keyboard command that needs to be inserted? that is disabled? I know it is not possible that from the point in white everything disappears!. .
I thought I was clear (see above):
and the right mouse button what does not work?Don't you see the menus? in this case go under options -> user preferences -> quick choice menu in the design area.
that must go out naturally. . .
...then I have changed the working area not and more acad.cui because if I write menu and activate it all the commands from the first to the last disappear all . why? how can I do? Also because as I have to do university deliveries if I don't hurry I'm done. What if I don't uninstall it? And I'll take it back, but then a slaughter I already know! Thank you very much
but in the classical work area, at least from what I read above:
.... me and reappeared all by putting acadsampleworkspaces menu but the same does not work me the right mouse button. How do I do that?
You know, everything works for you. is it not good to start from that and, moreover, only with that does not present the problem of the "sevening" of the bars?
I'll send you my acad.
is the original in Italian, I have never made customizations. (I do not use acad 2009 )
for what concerns the dx mouse button, if you type " options " opens a window where, in the tab " user preferences " --> " windows std operation ", there is the " customization button dx " button.
from here you can choose how to make the dx key of your mouse act.
Bye.
ps. : I can't tell.
do not use accents?:biggrin:
thank you thank you all very much!!!!!! I managed to make everything work again!! I copied the acad.cui that was sent to me by brown stefano (thanks 1000) , replacing my ... puff is reappeared all correctly and the dx mouse button works again magically! I did not know the malfunction of my acad.cui there was no option user preference button dx that worked, but the important is that everything is fine and I will succeed in delivery. I'm sorry for the accents but in total panic I couldn't correct Italian. Thank you again
I am at your disposal.
thanks 1000 to all of you
Franciscan
Good morning.
I also used your advice and restored autocad, from which the acad.cui file disappeared.
Thank you all.
Matteo
boys, I also followed your advice and two weeks after the exam you were my salvation!! I happened the same thing that happened to Franciscan and thanks to the acad.cui of stefanobruno I managed to solve the problem! Thank you very much!!
Thank you, it seems that I solved it too thanks to your suggestions.. I can't believe it. I'm almost touched.
I'm sorry
hello to everyone, after finally recovering the file to which. I can't change the menu in any case (to tell us about the old version type 2004 etc.) or import new commands, as it tells me that the acad.cui file is protected by writing. I tried to create another .cui file, but I couldn't do it anyway. . Cheddire, thanks in advance...:frown:
This problem was found in a pirate version of autocad 2009, I know for certain because I know several people who had the same problem.
I dare to assume both your own case.
we have 2009 fired and in 3 years never happened is what!
What do you think I have done today for making all my toolbars disappear and find myself lost in a black worksheet without anything except the gray bar above with the a in small and the icons below? ?
It seemed to me that I had already happened once and that a friend had given me a tip to make her reappear...type of crushing f12...what happened before?
However thanks to the stefanobruno file I was at least able to recomparise some toolbars....even if before I was used to working with the classic version of autocad and not with the tops that incorporates all the sections....say I had my own custom profile ad hoc...that now has been lost.
of course before resorting to the stefano file I tried/tipped all without result.....
Anyway, I never had a thing like that. .
if someone had suggestions....
the "mother" of all the straights is to always make a "exegui migration custom settings", if necessary you can always import the exported file. :smile:
