ygna
I explain briefly how I shaped the church (in mm)
structure:
- Young module: 180 m
- polka dot coefficient: 0.25
- density: 1.8^-09 ton/mm3
element solid65
cover:
- module of young in parallel direction to the axis e1 = 11700 mpa
- module of young in orthogonal direction to the axis e2 = e3 = 830 mpa
- cutting module g12 = 700 mpa; g13 = g23 = 70 mpa
- coefficient of poisson υ13 = υ12 = 0.42; υ23 = 0.35
- density ρ: 0.4^-09 ton/mm3
solid element
constraints to the base define loads– apply – structural –displacement – on nodes null shift in all directions.
for coupling/ceqn beams – couple dofs for each beam I selected six faces (maybe I had to insert the trolleys in all areas in contact with the structure).
for the analysis freqb 0 ; freqe 0 ; nrmkey to mass
the null frequencies are much but much more than 6..
I don't know how to do
structure:
element solid65
cover:
solid element
