itaranus
Hello, everyone.
I just started using ansys and can't get good results regarding the problem I describe below:
I imported a set from solid works to workbench 14. all parts of the aid are recognized perfectly and I have no problem with the areas where the parts are in contact! I define a fixed support and get the result of the simulation without any error.
the problem however is that ansys vibrates my structure "trave" around au axis. therefore the vibration is in the direction not from me required.
Imagine drawing a rectangle on the xy plane and then extruding it along the z axis! I want the vibration along the z axis and not around the z axis. In other words it is as if I wanted a vibration due to an orthogonal force on the xy plane. instead ansys simulates the vibration due to an orthogonal force to yz (apply force on the sides of the beam and not above).
You know how I can solve this problem?
Thank you in advance.
