Model tree - is it possible to export values?
  • Thread starter Thread starter AK-47
AK-47
Good morning.
2 questions:
1. Is it possible to export the values of a model tree of a set?
For example, we put that my modl tree (the columns) contain values for each part of mass, material name etc.
is it possible to automatically export them to a file (for example excel or txt) so you can use them in a calculation sheet later?
2. the mass value of the parts is sometimes in grams, sometimes in kg. I tried to give the same unit of measurement both to the parts individually, and to the assemblies, but I can not get out. continues to present me some masses in kg and others in grams. not putting the unit of measurement, I have to go every time in the part and through the analysis of mass properties, understand which unit uses for each component.
This also happens in tables that I use automatic in the tables.
thanks and friendliness
...I would like to export the mass values as in the attached image. .
Bye!
If I understand what you want to do, it should be simple.
above the model tree there are 2 menus, "show" and "sets", click on settings, save tree model......
by default it proposes you as file name "treetool.txt"....
if I don't go wrong save the file in the work directory.
:smile:
