CiccioViol
Hello everyone,
I'm a new user, my name is francesco.
I hope you can help me with this modeling problem.
< I have a structure (composed by several parts) in which there are various bolted connections (I would like to check) so I need to use a "bolt model" from which can read the agent voltage and (magari) to which can apply a preload.
I've been documented a bit, and I've been oriented towards the technique that shapes the bolt stem as an element beam and the head of the bolt as a "network" of rigid elements, the preload would be a thermal load.
but the results I get are high.>>>
- you would know how to correctly assign the properties to the bolt, known: the stem diameter, head size, preload??- or would you have references or examples to which to refer??-I discovered the existence of a patran tool dedicated to bolted joints, some of you have ever used it??I thank you and hope that this debate will be of general interest.
