hello to all I have a problem when I perform the helical function. I get the error you can see in the annex...the strange thing is that I'm sure the lines I built can't intersect.
It may be that maybe you're wrong to deal with it and that instead the problem is there, or no fag... comunqeu better than place the inventor file so that we can evaluate on the model.
I don't know, with your sketch and your data with inventor 2010 works, I see you have the 11th, I don't know if it depends on a bug of that vesion. have you installed all the updates sp and hotfix?
then maybe it can be a problem of version 11, with 2010 I did with your data by swapping them between them (pass, revolution, height) and both positive and negative and the result I always have.... I don't know... tried hia to give it a bigger step just at a time to see when and if it comes sooner or later? Maybe you don't need it, but so much to see... maybe a 2.1 then 2.2 then 2.3 for example... .
