models with different location
TECNOMODEL
I have to create a model for a particular type of table where the cartouche will be placed up.
Of course I already have a model in which the cartiglio is in the classical position.
this setting I found it only in application options, so it means I would have a conflict between the two types of tables.
can I set the position of the cartiglio only in that model?
or do I have to make the cartilage along with the score?
side browser > dx button on sheet1:1 (or what is) > change sheet > opens a form and there is a possibility to choose where to put the cart.
My goes a little bit away (but in the "right" direction) so I suppose it's necessary to set up hooking points. . .
if you refer to the cartilage you can copy it from idw to idw and have multiple carts available in the same idw, which you will find listed sepre in the lateral browser in the folder charts
I am creating a pattern of a work cycle and I have to have the cartilage up, if they select the option you were saying from the browser in edit sheet then it only keeps it in that model?
therefore each table created using that model will have the cartilage at the top, the other created with the existing model will continue to have the cartilage at the bottom. Right?
I think so, but obviously the only one is spending 2 minutes and trying, which is always useful to learn how things work.
You want me to prove it for you?
