modification contour view design - 2d
Strego
Good morning to suits,
I have a problem with the table: I can't change the outline of the design view.
in particular I would like to discount some views in such a way as to better use the space available on the table and not have views that overlap to others.
Thanks to who can help me.
roberto
is very simple, click on the button indicated by you and act on the contour geometry. What can't you do?
Thanks for the answer.
in any case, I open the modification of the contour but used the command line (from ''drawing''') does not accept the input. I can only change the existing rectangular fence.
version of solid edge used? Do you have the last mp installed?
Do you have the problem with all the drawings or just a specific one?
solid edge 2022. excuse ignorance but what is an mp?
The problem is with all the drafts. Thank you.
maintenance pack, are updates that solve the problems reported by users.
for solid edge 2022 has just exited the mp6; I suggest to download it and install it
p.s.: is cumulative, it is not necessary therefore to install the previous
as soon as I have availability I will do as advice and give feedback. Thank you.
