R76
use rhinoceros for less than 2 months, I read a lot, but I can't solve the following problem.
I am trying to create a mold, I attach the file and describe in short the various steps.
1) I created the object I need without too much trouble
2) I made the division line between the two parts of the mold
3) I used extruded strip curve to extend the division line and filled the belt center with a patch
4) I created a cylinder (the mold)
5) I cut in two the cylinder with the surface-ship
Now it's all about subtracting the solid from the two parts of the cylinder, but I can't, it always gives me a failed boolean difference.
the problem I think comes from the way I cut the cylinder.
Am I wrong? What is the correct procedure?
Hello and thank you
roberto
edit
by exploding the surfaces and going to eliminate the ones that do not serve, I can get the mold in negative, but if there is a better procedure well come.. .
Hello and thank you
roberto
edit
