monolithic scale with non parallel lifts
  • Thread starter Thread starter infoblulinea
infoblulinea
good evening, in a refurbishment I find myself building a monolithic scale with the lifts not parallel to each other; revit draws me the finish (lifted and peeled) but not the monolithic part of the scale... Does anyone know how to help me?
Thank you very much
using the drawing scale (not for components) you can draw the lifts as you want, not only not parallel but also shape any
Thank you very much for the answer.. .
I did as you say, unfortunately when I diverge the lines of the lifts, I disappear the monolithic part under the staircase.
use revit2016...how do you attach files? I can't load. . have a maximum size?
