more materials in the same component?
  • Thread starter Thread starter Ranger_Trivette
Ranger_Trivette
inventor allows me to create within a more solid part.
However, I cannot assign different materials to the various solids that make up the part.
Is something wrong or not feasible?
It's not feasible.
Tell me why you're a part of more solids?
there are assemblies for that, where you can also assign materials to each component.
concordo con stefanobruno
I assume that managing everything in multybody is convenient for "simple" details, but then having a distinct and different materials, the only solution is to transform the part - multiple in combination automatically through the management command " creates components", then by the axieme that generated change the individual materials. If the parts are many, change from within the distinct materials, you will have a overview and you will be able to use the paste copy between the cells.
remember, since they are all derived parts of the origin model, the changes always make on the main multybody part
igo example in iv2018
Sto stuff of creating components is op
I didn't know her.
Thank you very much to all!
I tried.
I go on creates components, selects the various solids, but at the time of clicking on ahead a window opens with writing:
"Impossible to open the default template file"
what can be due to?
you must select the template file from which to start (as similarly when you do the "file-new" command
