romina giu
I have a problem in a contact simulation between a assembly created by me and a solid converted from a stl file; for the simulation I opened a new assembly, if I first insert the solid and then the assembly gives me everything totally defined while if I first insert the assembly and then the solid simulation does not go even if it is not strictly defined.
Is it wrong to determine contact groups?
Is it possible to perform such a simulation?
the assembly designed by me, which I use in the simulation, is formed by so many spherical joints between extruded cylinders......moving it simply with the mouse moves, but I do not understand why it does not move in the simulation, perhaps are too low the forces that give me contact?
