meccanicamg
you simply need to use the size and extrude it on solids. Take the wheels you made, save them by name and work on the newly saved copy. You do the extrusions you want, obviously the toolbox change doesn't work properly because it brings back the wheels to the origin, you can only work as if they were solid any.to calculate the coupling shaft hub, I had considered a coupling length equal to the band width. the professor told me to consider as width of the coupling a value about 1.5*diameter of calettamento. Now, however, I do not want to go to change everything for such a thing and I have considered a coupling width of 90 mm (diameter of 70 mm). apart from this detail I have already discussed with him, I can't bring this stretch back on the solid design!
is worth the same speech (only the part of the drawing) for the conical wheel.
place two designs to try to make you understand! with the arrows I'm going to tell my problem! all the parts indicated with the arrows are parts of the wheels and not of the tree (do not mind the error on the section of the cylindrical wheel, because there is the wrong diameter).
I hope I've explained
