motor torque (time) in a dynamic simulation
  • Thread starter Thread starter makeng
makeng
Hello, everyone.
despite me the cable quite well with mechanism dinamic ext, I have a small problem: How do I simulate a motor torque ? this netity must be expressed in newton*meters, or dn*m. what I need is to insert a motor within a dynamic simulation, to virify movements, times and accelerations. cigliegina on the cake would be able to insert the characteristic curve torque/number of turns. Is that possible? Is there someone who can do it?
Mar
Hello makeng,
there is the force engine where you can insert everything you want.. .
mechanism>forcemotors>new and in the drop-down menu you will find table driven or user defined that allow you to insert table or acceleration formula respectively.
if you have mathcad you can also connect a chart from which you get the expression.
I saw, thank you. actually he recognizes alone whether it is time or strength. the additional problem is that in the axieme there are several parts with different units of measurement and high mass properties. I must first put everything in place to see if the simulation is correct. Anyway, thank you for your help, then I'll let you know.
