motorcycle simulation gears
  • Thread starter Thread starter lollone
lollone
Hey, guys.
I'm trying to simulate the transmission of the bike through gears.
Does anyone have an example or can you explain how to do it?
bind gears with pin or cylinder type motion connections, then go to insert > gearing applications, click on the respective motorcycle axis of the toothed wheel torque, select the rotating rod and specify their diameter.
I have a transmission ratio 1:1
the dentate wheels are the same.
I thought I would bind the second tree so that you roar together with the first giving it a orientation bond, but I can't.
is there no way to bind the connection without going into the mechanism module?
If you only need an animation without a cinematic analysis.
You're definitely less than...
apply to the two shafts (or the two pinions) two servomotors with the same rotation speed and you are in place.
to do this you must use the pin bond instead of coaxiality.
cmq if I give the 2 shafts constraint pin and imposed on the mechanism the connection gears are affixed.
But I couldn't pick up on another question. . .
If I have 2 trees and want them to rotate in the same direction how do I bind them?. I couldn't do that.
Then I realized that it is enough to bind the first with the pin, the second I give him the reference of orientation on a plan of the first, but I have to remove "permitted" immediately because after it does not allow me to do it.
now the second tree rotates with the first.
if you use the mechanism> gear function to reverse the direction of rotation simply click on the inclined arrows of motorcycle axis in gear2
