mouse pointer problems with autocad
  • Thread starter Thread starter gantoniol
you found several posts, but you didn't link one to better understand the situation and read that attempts had been made.
autodesk has a assistance that should be set up precisely for these needs
discussions cannot be closed; and it is right so because a solution, clarification or interaction can be made even after months.
if you ever find a solution you are prayed, in the spirit of the forum, to share it
I'm sorry, I didn't mean to close the discussion as to eliminate it, I meant I didn't want to make a controversy that I didn't think was constructive for the solution to the problem. Actually, I didn't think to attach the posts and keep it as a reminder for subsequent interventions. Of course, if I find the solution, I'll share it. I apologize again for explaining me badly and wish you a good day to all.
the atypical thing is that the problem is the same on 2 completely different hardware, with different video cards (also in the brand), different memory quantities, probably different storage.
a problem on a certain combination of hardware/software is always around the corner, and it is possible that (invent) on 10,000 installations arises a problem on 20 installations. (the 2 per thousand)
that an identical problem on different hardware, but of a single user, begins to affect the calculation of probability.
What is there in common between the two pcs (user separately)? are there programs that you have installed on both, (type vmware, virtualizations) ?
Did you get any malware (which would explain propagation to both)?
Do you have any torrent downloaders loaded at startup?
I think you need to search the side of the problem, not so much in autocad.
Good morning, thank you very much for the answer, now I'm going out, this evening when I return to the office I will try to verify the things you suggested to me and see what happens. I will keep you updated on developments.
good day, I wanted to update you on the problem proposed, in the sense that after a few weeks of trials and attempts I noticed that the problem was presented late afternoon after a working day in autocad. the solution I found and reboot the pc and everything goes back ok. now I don't know what it depends on and if the solution I promised is correct in procedural terms, but since the desired effects for me arises well... Also in the time that everything reboots I take a small break.. .
