move all database parts and assemblings
  • Thread starter Thread starter Loutenr1
Loutenr1
hi guys, I'm still addressing you for a little question:)
I turn in the head the misana idea if it is possible to keep all the files part and the files together (say all the work) on a portable hd so that you can always work on the same things from one station to another that are not on the net (no server therefore). Is it feasible? :smile:
If that's why you can also work with the key :biggrin:, apart from the slowness... :cool:
eye to the toolbox components.
Okay. Perhaps the toolbox would tell me that it does not find the right components? and if you take the same path as the toolbox on the two machines?
if you have left the standard options and that is create configurations for each variant, from solidworks 2009 there is no problem.
if you don't find them, recreate the missing configuration.
Okay, but would you solve the problem? :smile:
to get the 100% response (I never used the student, and not even 2008), do a test with a set, insert the elements of the toolbox and if, once you set the paths, it opens you all without problems you are in place.
Do you have the same sw version on the two pcs?
the boy has studend2008... He'll have to do a test like I wrote him up here. .
thanks to both:finger:. I will make some evidence, but fortunately for now I do not use the toolbox (not "lucky in the sense that it sucks, but in the sense that if it does not work with the same directory I do not lose anything)
