Staedtlerp
Hello everyone,
I have a problem with contextual design, and to make you understand in a simple way I will proceed with an example. I have a catproduct in which I created a main part and other parts connected to it (I worked in contest with links between the parties). all right here.:finger:. after a while I had the need to create a subaxieme and insert inside the main part, the one to which the other parts are connected. I realized this, simply dragging the single part into the new created set. immediately after the other parts became red (not updated) and following the update I appeared the notice in which were listed all the missing references of the parts bound to the main part that was moved:
"Impossible to sync: the element, from which the reference is created is manacante. "
the strange thing is that the parts in context did not change their part icon, but they maintained the typical part in contest, that is that with a blue gear and a green one and the two chain rings to indicate the connection with another part.
I was wondering: is it possible to move the main part without losing the links that the other parts have with the moving part?? Do I have to rebuild the links?? ?
:confused
Thank you very much
Thank you very much
