move face & match
  • Thread starter Thread starter volaff
volaff
Good morning.
I have a problem with the commands in question.
I wanted to fill the space between the green object and the blue one (which are separate bodies within the same part).
I had thought of first using the command moves face, shaping the piece in green according to the blue one, and then making a "abbina" in order to have a single body.
By adopting this strategy, in fact, the match command does not work by clicking on ok nothing happens.
Inverting the order of commands is the match but I can't do the move face.
I thank everyone who wants to help me.
Greetings.
fly
except that view so you only understand what it is.
cannot at this point create directly a solid that its final result?
but then are pieces shaped or imported from step or similar?
Maybe you're gonna have to move two and then a match. You have to see that you create interconnection between the two solids, otherwise you don't match anything.
I can't understand the general geometry very well, but it is clearly seen that the blue part intersects the green one. I think it's a condition where certain commands can even mess up. According to me you should extract the surfaces that intersect, trimmarle so as to leave only those corresponding to the actual vacuum filler then make a filling between the two upers and then merge the oil obtained to the green or blue, depending on what you want to get.
