speedfish
Good morning, I wanted to ask you, if someone has experience about it, how you can move a spline on a certain point, I will explain better: I draw the profile of a gear I find myself in the condition of making equal the thickness of the tooth with the recess (on the primitive circumference) so as to have mating without play; for example I have an ingration with primitive 25mm (ring) and module 5 (10 teeth in total), each tooth spans a corner, at the base of the primitive of 18°, only that, in doing so, the thickness of the tooth and that of the recess are different; I tried to select the middle point of the arc between two successive profiles (half of the step) to move the other profile of the tooth but it does not allow me in any way to move the spline, does it exist any way? place an image to make the idea better: as I move point 1 (all spline) on point two maintaining the condition of accident (and then also rotating) on the base circumference and on the head circumference?
