move the rows inside the local abacus
  • Thread starter Thread starter Strumble
Strumble
Hello everyone, I have a problem. I have the need to reorder the abbot of the premises in numerical order, how can I do? My building consists of three levels: the rooms on the basement are named lg01, lg02,... on the ground floor gf01, gf02... and on the first floor ff01, ff02... some locals having added them later, are located below. If you rang by name you see me first the ff01, ff02..., then gf01, gf02... and finally lg02, lg02. I would like to order the plans from below up. I'm sorry if the question is going to be very trivial for so many of you, but they're in the first place. If you could explain by step I'd be grateful!
you need to use another parameter, like "level", or a new parameter like "order" (number). this parameter must have the numbers corresponding to the order you want. next, order the abacus according to the values of that parameter.
as the good alfredo rightly says, you could create a project parameter combined with the premises charged sequentially allows you to order as you prefer the abacus (then the column can also be hidden); or without using custom parameters you could use a system parameter already inserted but that is unused (such as the "repart")
or, more simply, renumber the premises starting from a high number (type 99) and order vice versa
...if the premises are not hundreds:)
Thanks for the answers! I'm trying to "add parameter", and how do I choose number is correct?
edit...
I have a doubt: in case I have to add another room I have to rewrite all the hidden column numbers to put it back in place?
I have a doubt: in case I have to add another room I have to rewrite all the numbers of the hidden column to put it back in place?
but unfortunately, There are also apps that automate is what but are paid. There's dynamo. .
Thank you so much for your help! I don't know dynamo and we don't have it in the office. Can I take advantage of your kindness again? in the room schedule cells when I write something revit records what I wrote, so that makes things easier. But sometimes it happens that when I select that certain phrase in the drop-down menu, and it always happens for long sentences, it cuts my sentence half and I just don't understand why. Could you let me down? It's really annoying! :
