moving building - error messages
  • Thread starter Thread starter elieli
elieli
Good morning, I have already designed a 3d model of a building in revit, now I have to move it to the interior of the plot of land.
I have selected everything well, at the time when I try to drag it there appears a symbol of ban and an error window, not ignoreable, which says that "the elements can not be moved simultaneously. for some there is a limitation for which they can be moved only in one direction, for others a limitation, for which the elements are moved in an invalid direction". I have not revit in Italian, so the translation could differ from the original message in Italian.
Can you help me?
Thank you very much in advance. Bye!
But why does this work flow like this? When he says that you want to move the building inside the ground lot, that seems very strange. and how do you move it? like a file? Why does not create the ground in the same file where the building has already done?
thanks to the cold. in the lot there is already a building, the second building I have to move it inside the perimeter, at the due distance from the other. I just need to drag it, but obviously there are some elements with parameters that prevent this action.
continue to use revit as autocad. It doesn't work that way.
You should have done a file with the lot and one with the building; You connected the building to the lotto file and dragged it where you wanted to
I recently use revit, I think it has centered the problem! do you mean by the command enter-->link cad? In the end I managed to drag the building (not as a file connected as you say, I mean as I originally thought, that is designed within the same file and simply translated) , but I lost information ahimé! next time I need a better method, connect the file sounds better. Thank you.
