mp13 per se st1
  • Thread starter Thread starter Tequila
Tequila
per chi ancora non è passato alla st2 c'è l' mp13 disponibile per il download
this maintenance pack addresses the following prs:
=====assembly=====
pr 1762903: unsuppress of a pattern was not recreating the slave parts
pr 2133252: solid edge st mp10 aborts while trying to import an assembly from nx3.0
pr 6146834: solid edge is crashing while attempting to place fasteners
pr 6248060: relationships failing when replacing a subassembly using same base part
pr 1702605: parts have wrong position after replace part, but system gives no error
pr 6242099: failed pmi dimension appears to dramatically affect performance in this assembly
=====part/profile/sheet metal=====
pr 1757659: divide part doesn't support rename of the child anymore - regression
pr 2086784: assembly section view is not cutting the body
=====draft=====
pr 1753646: abort occurred after entering invalid characters on the table style line type page
pr 2124797: dimension changes when opened in v20
pr 2135361: a phantom sheet showing up in draft file
pr 6234965: pasting into a feature control frame causes solid edge to abort
pr 1715016: dimension values will not move, when the drawing view is moved, regression against v19
pr 6276308: solid edge is crashing during save after placing a connector, then deleting it
===insight===
pr 6270672: solid edge crashes if you close the search dialog before list refreshes
pr 6270698: solid edge crashes if you click search before the old list is processed
pr 1759457: copy alternate assemblies inherits wrong member
===api===
pr 6268536: sereader failing to open assembly locked by solid edge
pr 6272116: heap overwrite detected when 3dconexion add-in is running
=====embedded client=====
pr 1754089: assembly structure links are broken with "hide all components"
pr 1754460: pse bom doesn`t synchronize although "seec_bom_synchronize=true"
pr 5937465: error message, "checked out by another user" when downloading files from cache assistant
pr 6199990: synchronize all in pathfinder does not update bom changes
pr 6213940: improved seec search time performance
