mp5 per solid edge st2
  • Thread starter Thread starter Tequila
Tequila
rilasciato il maintenance pack 5 per solid edge st2, sia versione 32 e 64 bit.
per il download si rimanda al sito siemens
bug corretti
this maintenance pack addresses the following prs:
=====part/profile/sheet metal=====
pr 6309592: move faces fails after contour flange is created
pr 1774806: move face along normal causes a crash
pr 6250532: cannot separate thread features
pr 6225694: mix and match of internal and external threads causes flip
pr 6309497: cannot create a contour flange with circular cutout close corner
pr 1775239: rebend command fails on lofted flange
pr 6306564: cannot move a bead made with a point
pr 1771620: synchronous functionality becomes very slow due to simulation study
pr 6308114: opening a sat file in st2 does not work as it did in st
pr 6310904: cannot create an extruded cutout using from/to in st as you could in v20
pr 1753614: chamfer with equal setbacks at non perpendicular faces are not maintained
pr 6279672: fixed distance not maintained editing 3-point dimension in the provided file
pr 6277212: a feature in the provided file fails to recompute
pr 6182369: cannot rotate a flange with locked dimensions
pr 6295337: curve by table yields an error in windows 7
pr 1754685: flat pattern length is incorrect
pr 1778169: unable to mirror a model which includes a pattern
pr 1777789: unbend/rebend converts an edge to curve
pr 5777698: section view creation fails
pr 6317234: unable to flatten lofted flange
pr 6292472: getting a difference in flat pattern results if a cutout exist
pr 6304690: normal cutout fails in simple scenario in st2; but worked in st
pr 6310905: cannot access a premium license when the license contains an xpresroute feature
pr 6285483: fixed distance not maintained when editing an angular dimension by line and point
pr 6311566: se hangs when recomputing a model with a large number of holes
=====assembly=====
pr 6310200: scroll to part not working correctly on patterned subassemblies
pr 1777601: performance impact in pathfinder using read/write combo with name formula
pr 6271761: assembly patterns do not support fill pattern region patterns
pr 1772728: assembly pattern of a pattern is not updating correctly
pr 2138603: solid edge aborts after clicking on update physical properties
pr 6305865: a part is missing from a sub-assembly after exporting a step file
pr 6310188: selection manager is not being displayed for inactive parts in sub-assemblies
pr 6303351: unable to place an additional stitch weld in the provided file
pr 6314723: pasting a material into session entities causes the tree to collapse
pr 2134733: parts list is incorrect for an foa member
=====draft=====
pr 6281484: text styles are incorrectly allowed to be deleted
pr 6292537: poor translation for several poly-lines in the supplied test case
pr 1774207: grouped callout text on background sheet is not exported to autocad model-space
pr 1780070: unable to copy and paste
===insight/view & markup===
pr 1767221: graphical webpart shows an empty edgebar when using ie8
pr 6308098: getting an error when copying documents which have excel links
pr 1769510: insight warning when modifying a fop member
pr 6294483: revise prompts for a save on a released document
pr 6294471: revise does not complete correctly on asm when using a revision rule on file open
pr 6294205: get no warning when opening checked-out files, all buttons enabled
pr 6216819: undo checkout on active document doesn't disable the save button
pr 6284707: cannot get a full text index created
pr 6311898: get an erroneous message about revision rule when saving an assembly
pr 6316302: unable to set up an insight sql server user
pr 6302147: sub-assembly cannot be moved from available to released
=====embedded client=====
pr 6310274: deliver overlay templates for teamcenter 8.1
pr 6307690: %{sheet number} and %{number of sheets} causes unneeded save for draft
pr 6310789: folder dialog displays underneath the add to teamcenter dialog
pr 6295933: the revision rule dropdown menu will not display the last available rule
pr 6312980: save copy as on an assembly doubles the quantities in teamcenter
pr 6317107: seec fms errors..... on file close upload - misleading fms error message
pr 1694547: problem with assemblies created by save as from legacy edge-manager assemblies
pr 6322498: driving addtoteamcenter via a command line displays the broken links dialog
pr 6298034: problems with memory consumption when adding customer files to teamcenter
pr 6296650: in-place-activating files in seec can take 10-30 times longer than file/open
pr 6321432: manipulations in assembly bring an fms error
pr 6324227: enable additional instrumentation/logging
pr 6324551: from linked 3d command does not copy the project name property
end
