msc adams - error during simulation
  • Thread starter Thread starter mauriziot
mauriziot
Good morning, everyone. My name is maurizio and I am involved in the development of road cars. I have a problem with a simulation. It gives me a mistake during the simulation. I attach below the detail of the error that comes out to me.
reading in property files...
reading of property files completed.
setting up assembly for analysis of loadcase: 'parallel_travel'...
writing analysis information to adams/solver command file: 'a_parallel_travel'.
simulation(s) are beginning...
os-environment variable
msc_use_fortran_style_reload_message_file=1
asol sdk. enforces adams/solver c++ to use the adams/solver fortran message file style when reloading.
command: file/command=a_parallel_travel.acf
command:
command: file/model=a_parallel_travel
adams/car adams 2013.1
processing environment entries in 'c:\msc.software\adams_x64\2013_1\acar/acar.cfg'
processing environment entries in 'c:\users\maurizio1/.acar.cfg'
os-environment detected: mdi_cdb_search=no
adams/car will restore the cdb search algorithm from version 12.0 (if set to 'yes').
usage of this environment variable is strongly discouraged.
os-environment detected: cosin_prefix=c:\msc.software\adams_x64\2013_1\cosin
for defining the path to the cosin software installation when a user defined version is preferred.
os-environment detected: msc_multiline_xml=1
adams/smartdriver will use multi-line formatting when instantiating xml driver control files (0 or 1; default=1).
adams/tire
version adams 2013.1
reading configuration file 'c:\msc.software\adams_x64\2013_1\acar/acar.cfg'
reading configuration file 'c:\users\maurizio1/.acar.cfg'
acar_2013.1.0/ac_scc_init
reading array parameters using the
adams/car array statement definitions.
checking array parameters...
| model title |
| adams/car assembly (adams 2013.1) |
command: preferences/solver=cxx
command: preferences/status=on
command: control/ routine=acarsdm::con950, function=user(950,29,31,1,2,18,20,1,3,2,3,28,30,2,3,28,30,1,1)
begin static solution
time t=0.000000000e+00.
degree-of-freedom analysis identified redundant constraints in the model:
- deactivating constraint equation si.yj in model.evo37_posteriore_v06.jortra_spring
- deactivating constraint equation si.xj in model.evo37_posteriore_v06.jortra_spring
- deactivating constraint equation si.yj in model.evo37_posteriore_v06.joltra_spring
- deactivating constraint equation si.xj in model.evo37_posteriore_v06.joltra_spring
- deactivating constraint equation si.xj in model.evo37_posteriore_v06.jortra_strut_joint_1_rear
- deactivating constraint equation si.xj in model.evo37_posteriore_v06.joltra_strut_joint_1_rear
- deactivating constraint equation zi.yj in model.evo37_posteriore_v06.jkrrev_upper_arm_front
- deactivating constraint equation zi.yj in model.evo37_posteriore_v06.jklrev_upper_arm_front
- deactivating constraint equation zi.yj in model.evo37_posteriore_v06.jkrrev_lower_arm_front
- deactivating constraint equation zi.yj in model.evo37_posteriore_v06.jklrev_lower_arm_front
statics: original static solver will be used with the sparse linear solver.
---- start: error ----
static equilibrium analysis has not been successful.
the maximum number of iterations 25, has been reached.
for the last attempted iteration:
the equation with the largest error was model.evo37_posteriore_v06.dal_force_damper_2_fron.force comp = 0 error = 1008.725791
the variable receiving the largest increment was model.evo37_posteriore_v06.gel_damper_1_rear comp = 5 delta = 26157.515217.
---- end: error ----
static solution failed to converge
end static solution
simulation failed
initial static sim. not successful
id = 0
adams/solver run terminating due to stop requested by user.
termination status=-995
terminating adams/car usersubs...
finished -----
elapsed time = 0.41s, cpu time = 0.33s, 79.45%
analysis failed!
please check the error messages to determine the cause.
uno riesce ad aiutarmi? grazie in antici
