xLOGANx
Excuse me! Has it ever happened to any of you to get a message like this in the middle of a simulation?
an internal solution magnitude limit was exceeded. please check your environment for inappropriate load values or insufficient supports. also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. please see the troubleshooting section of the help system for more information.I press that, for reasons of excessive weight of the model, I had to transform some solid elements into surfaces (with the mid surface command). In addition, the model has an aluminum base bound by steel longheron bolts: I set the frictionless as a state of contact surfaces.
