multi body
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
I made a multibody welded object then I made the table and I would like to exclude a body leaving it not dissected but it is not possible you have a solution?
I would like to exclude a body leaving it unspoiled but it is not possible for you to have a solution?
in the multibody you cannot exclude bodies, which are not modeled with the nervation function, from the section.
@crazymad in the category "I open a discussion that I don't care about and will not follow"
a minimum of respect for those who answer ca@o!
simply having already read the answers where there is no solution I have no longer read besides the fact that I did not get the notifications because usually dear I answer and I always follow every answer with interest but maybe for you and easy to judge without knowing happy you .... good continuation
simply having already read the answers where there is no solutions I no longer read.
However, it is education to give a response to those who respond to the discussion; otherwise to say that the discussion no longer has utility knowing that there is no solution.
Do you need a notification to remind you that you opened a discussion?
In fact...
bears for you and easy to judge without knowing
as I judge from what I read. I have no psychic powers.
Do you know that there is no answer to your question? Write it down! ! !
