gianmauro
Hello, everyone.
Sometimes I happen starting from a simple sheet of having to cut it by rendondola several pieces.
At this point I find these problems:
I follow this procedure:
first body
-view of the model
- My files
-select multicoropo
- I choose the body I want to put on the table
- orientation "flat recetition"
- sending
result all ok, you generate a default configurationdevelopment
second body
Sometimes it happens that you do not generate defaultdevelopment1 and at this point I am screwed.
if you generate defaultdevelopment1 can happen that repetition is without bending lines.
looking in the tree relative to the known view that under "flat recetition" , bending lines is turned off (normally it is lit).
if I turn it on I see the folds on the table but, not the notes even if the property of the view "show notes of bending of the sheet" came out.
Can anyone help me?
Thank you and good Easter! !
first body
-view of the model
- My files
-select multicoropo
- sending
second body
Can anyone help me?
