multibody simulation with elastic elements
  • Thread starter Thread starter valebiro
valebiro
Good morning to all
My name is valentine and I am writing to ask you for advice on simulation software.
the simulation that I need to develop concerns the anti-rebalt test of a truck with installed a hydraulic crane.
depending on the movement of the hydraulic crane there are some configurations in which the truck is unstable and tipping.
the peculiarity is that during the simulation it is important to consider the deformations that the crane structure and the chassis of the truck undergo, and to evaluate the influence they have on the point of tipping. it would also be interesting to be able to assess the influence of suspensions and tyres.
the simulation in question is therefore a multibody simulation with flexible bodies.
The idea is to use a software that somehow doesn't make me too expensive to model tyres and suspensions.
Any ideas? ?
I among the software I’m considering are:
amesim (module 3d integrated into module 1d for modeling tires and suspensions with concentrated parameters)
fedem (of smartcae)
ansys (thanks to the rigid body simulation module, but how to model tires and suspensions? )
adams (module view flex to simulate mechanisms with flexible bodies)
dymola (dassault systemes)
What do you recommend?? and among the software I mentioned which you would recommend and what not? ?
valentine
with ansys ( modal analysis + reduction) + simpack (multibody simulation) you should not encounter many problems, there are also tutorials for fembs simulation
