87527
Hello, everyone. I'm struggling with a problem and I can't find any material about it.
In practice I have a square plate of thickness x and sides 300*300 mm.
on one of the two faces of area 300*300, in the center, I have a circular area of diameter 55 mm where the temperature is maintained at a certain value t fixed (t>t environment). on all the rest of the face, on the side faces and on the lower face I have room temperature.
I need to calculate the heat flow from this heated surface area propagates to the rest of the material and then to the environment, depending on the x variable thickness and the thermal conductivity of the plate.
do you know if there is a formula that allows me to do this?
Please, if you know or have any idea how to do it and you can tell me I would be extremely grateful.
or I would just have a formula that led me to have an equivalent resistance and that made the problem one-dimensional.
Daniele.
I attach a drawing.
I don't know if I've posted in the right section, at most I ask
to the moderators to move (if possible) the discussion.
Daniele.
I attach a drawing.
