multidirectorate
  • Thread starter Thread starter Aurora_86
Aurora_86
Good evening,
I would like to know how I can center the text of the multidirector, in relation to the horizontal line of the same.
I tried to change some parameters of the "multidirector style", but without getting the desired result.
is the text linked to multidirector?
because it should adapt the length of the horizontal line according to the writing
the length of the horizontal line does not fit the writing.
In the bottom I attach the multidirector style settings so as to understand where the problem is.
But it doesn't work. the text is still placed at the right of the horizontal line.
there are under headings link to the left or right, in the case of the horizontal, unleash us a little.
I solved! I pulled out in the section that you suggested to me, moreover, I had to reduce the number of directorial points from 3 to 2.
