multidirectorate
  • Thread starter Thread starter MickSenna
MickSenna
Good morning to all,
reading other discussions within the forum and generally on the internet I did not find answer to my problem.
is it possible to remove formatting to multidirectors?
I have a file of a designer who worked in the studio before me and every multidirector has unique features. I would reset them all to the standard style and then manage the items from the style manager.
Taking properties and applying them does not work, and all multidirectors are with the standard overwritten style.
Is there a command/lisp to reset the multidirectors?
I thank everyone who can help me in advance.
It was enough to add a dwg to "activate" curious, so you force to simulate your problem with all the problems of the case.
the property arrowheadblock if placed to "" uses what defined in the current standard; setting it is relatively easy, understanding how many properties to reset is essential.
I apologize if I put the question incompletely. I attach an example file.
I have verified that the command that copies the properties, modifies the multileaders even if no longer controllable by changing the standard.
the chgallmd command modifies all current dwg multileaders with the parameters of the selected; is not exactly what you ask, creating a command that resets all parameters is complex and requires a lot of study.
Thank you. @rpor66 but as you said, unfortunately your solution does not solve the problem.
It seems absurd to me that a command has not yet been introduced in autocad to reset a multidirector (which instead exists for quotas or other commands). I am perplexed:
for now I'm setting the multi-directors "to handle". we hope someone else has ideas or solutions.
I created two commands that redesign the mleader and eliminate the old:
- Newmleader1, one at a time
- newmleader, all
to draw those with the left text I used an expedient, the first line of the director if it is vertical, I change the x of the second vertex of a small amount, it is not the maximum but it works.
I don't know anymore.
